Orbi WiFi 7 RBE973
Reply
Reverse lookup not working ?
Laurent78
Hi.
My model is AX1800 (not sure why it isn't in the list).
I do not succed to use the local internal resolver on my Netgear (DHCP activated). The local names that I've set up in the admin interface are not provided on PTR request.
For example (the answer should be SCP62328):
dig -x 10.0.0.18
; <<>> DiG 9.10.6 <<>> -x 10.0.0.18
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 10564
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;18.0.0.10.in-addr.arpa. IN PTR
;; Query time: 35 msec
;; SERVER: 10.0.0.1#53(10.0.0.1)
;; WHEN: Mon Nov 29 09:31:08 CET 2021
;; MSG SIZE  rcvd: 51
What am I doing wrong ?
Thank you.
Laurent
Message 1 of 5
Cooper152
Re: Reverse lookup not working ?
Make sure that your reverse DNS record matches the host name of your server. Make sure that a regular DNS lookup for the domain you have designated as the reverse DNS record entry returns the IP address in question. For example: If 70.32. 86.172 has a reverse DNS record of example.com.
Message 2 of 5
Szabo52
  1. Make sure that your reverse DNS record matches the host name of your server.
  2. Make sure that a regular DNS lookup for the domain you have designated as the reverse DNS record entry returns the IP address in question. For example: If 70.32. 86.172 has a reverse DNS record of example.com.
garageband
Message 3 of 5
Laurent78
Sorry i am still learning all this network stuff.
I was thinking the router would do this job for me.
My goal is to simply identify my devices on Adguard Home without static adress for all my devices. Is it possible to achieve that?
Message 4 of 5
CyberMarine
I have a question similar to the OP.  I have setup two separate DNS servers on my private network 192.168.0.0/24.  When I send reverse lookups directly to each server they work fine, e.g. `dig -x 192.168.0.1 @192.168.0.4` returns all expected PTR records with NOERROR.  However when I drop the DNS server argument (e.g. @192.168.0.4) and the request is sent to the router (a Netgear Nighthawk AX120 BTW), I get an empty PTR record and the dreaded NXDOMAIN status.  Foward lookups (either sent directly to each server or the router) also work fine.
Any clues, advice, or suggestions?
(Actually, now that I'm writing this, it occurred to me that at least one server is using port 953 in addition to port 53 used on the other server.  That probably has something to do with it.)
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1992 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
