Orbi WiFi 7 RBE973
Reply
Router configuration
Tek4Seth
Tutor
Hi,
My network looks like this for the moment:
- a router (connected to the fiber)
- my Netgear router connects to the other router on the WAN port
But I would like to access the whole network; and especially let the Netgear router manage what it manages for the moment (dhcp, rules, etc ...)
I would like to be able, from the PCs connected to the Netgear, to access the PCs connected to the other router.
is it possible?
thanks in advance
Message 1 of 5
Guru
Re: Router configuration
You're in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Basically you want the first router in the string managing the network. So you'd put the 2nd connected router in access point mode.
Message 2 of 5
Tek4Seth
Tutor
so this is not possible?
Message 3 of 5
Guru
Whats not possible? Getting them all on the same network?
Sure it is. You just need to only have 1 router actually managing the routing part of it. So if the netgear is what you're connecting as the 2nd router, put it in access point mode.
Message 4 of 5
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 780 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
