Reply
Router no connection, extender works fine?
Ecuadorianeyezz
Follower
So our router is saying there’s no internet connection, but when we connect to our non-netgear extender, we have a connection. This makes no sense because you’d think if there’s no connection, the extender wouldn’t work either. Any thoughts? We’re at a loss and the netgear support isn’t helpful because we need a support subscription.
Thanks so much.
Model: R6120|AC1200 Dual Band WiFi Router
Message 1 of 2
Guru
Re: Router no connection, extender works fine?
What modem/gateway do you have the router connected to?
Firmware on the router? (you have the R6120?)
What extender are you using?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 156 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
