Orbi WiFi 7 RBE973
Reply
Router
DrTech907
Follower
Router
After every rebot of the router or loss of power it always reverts to default settings. Does anyone know why it does this? It hasnt done this before
Model: R6900P|Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Accepted Solutions
Guru
Re: Router
What firmware are you on?
There was firmware updated in July. Maybe it caused a bug in your device. You can try downgrading to the version prior to it.
https://www.netgear.com/support/product/r6900p
Message 2 of 2
All Replies
Guru
Re: Router
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 584 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
