MarioBag's avatar
MarioBag
Slow Wireless Internet
I am having problems trying to get good WIFI speed using my Nighthawk x4s D7800  modem.  I am getting good wired speed (around 75 MBps) but around 20 mbps on wireless.  I am next to the modem and if I use a BT home Hub 5 I get 75mbps on wireless without problems.  I am using the latest firmware V1.0.0.48 for the D7800 ,
QoS and WMM are disabled and I already tried Resetting the modem. Can anybody help me?
Thanks in advance.
Mario
  • Retired_Member's avatar
    Retired_Member
    Jun 09, 2016
    Enable WMM and use WPA 2
    Retired_Member
