Orbi WiFi 7 RBE973
Reply
Speeds are slowed down when connected to router R8000
Hellraiser2167
I get 520mbps with my modem hardwired connected to my laptop. When I connect to the router I drop down to 265mbps. Any one have suggestions as to what could be causing the router to knock down my speed almost in half?
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
Guru
Re: Speeds are slowed down when connected to router R8000
what modem is it?
What firmware are you on?
Have you tried disabling qos, access control, parental controls, and traffic monitoring? (then reboot the modem after disabled)
Message 2 of 4
Hellraiser2167
Firmware V1.0.4.68_10.1.75
Qos- Off
Parental-off
Modem
Frontier Arris NVG468MQ
Message 3 of 4
Guru
traffic monitoring and parental controls are off?
Even after disabling them, sometimes a factory reset is needed to re-enable ctf that allows for faster speeds.
Also, your Arris NVG468MQ is a modem/router combo device
It can cause a double nat as well as it has its own qos/traffic monitoring.
https://kb.netgear.com/30186/What-is-Double-NAT
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 358 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
