swami7774's avatar
Nov 14, 2015
Switching between 2.4g and 5g.
I have a Nighthawk r7000. It offers two networks: 2.4G and 5G. Should I be able to manually switch between the 2 networks? I just tried to switch from 5 to 2.4(just to test it and make sure it was working), and I got an "unable to join network" message. Then I tried again, and my device (iPad) couldn't even SEE the 2.4g. FYI I recently downloaded the most recent firmware (1.0.5.44). Thanks in advance for your help.
  • rpoffen's avatar
    rpoffen
    Nov 19, 2015
    Simply changine SSID's and passwords shouldn't change anything other than clients will have to re-authorize on the new SSID.
    However, I have seen the router work fine and brick itself on a reboot :-(
  • General rule - reset the router to factory default after all firmware upgrades and reconfigure from scratch
    • swami7774's avatar
      swami7774
      Tutor
      I did the reverse: reset, then downloaded(I was having lots of trouble with the 5G). I reset to factory settings. Should I reset again?
      • netwrks's avatar
        netwrks
        Master
        The process is: load new firmware. Reset to factory defualt. Config from scratch.
