- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Technical question on external 3G/4G antennas for R7100LG 4G Nighthawk router
- Mark as New
- Bookmark
- Subscribe
- Permalink
On advise of another user I am placing this post here
Hallo,
I am using this 4G router in my mobile home with which we tour throught Europe. But the problem is signal-loss because a mobile home is in principle a cage of Faraday (don't know whether that's the correct translation). So I would like to help the router with external antennas. As far as I can find all 3 antenna's on this router are used for the mobile 3G / 4G connection.
My questions:
1. Is this a correct assumption that all 3 attached antennas are for 3G/4G connection?
2. When I would buy external antennas's should I replace all 3 or is 1 or 2 also Ok? If yes, does it matter which one?
3. Do you have any advise on which I should purchase (I think it needs to have a RP-SMA Male connector)?
4. Are these antennas always for only 3G or 4G or can this also be combined?
Hope to receive some advise. Thx.
Best regards,
Erik
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi evkrieken,
I am going to move your post to the correct location on the community so you can have better assistance. :]
- Jason N
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi evkrieken,
- Jason N
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
