Orbi WiFi 7 RBE973
Reply
The lights on my router
kkofron213
Follower
I have the first three lights lit up on my bran new router. I see there is a fourth light. Does anyone know what the light is for or should it also be lit?
Model: R6020|AC750 Dual Band WiFi Router
Message 1 of 2
antinode
Guru
Re: The lights on my router
> [...] Does anyone know what the light is for [...]
   Some might.  To join them, you might try this radical technique:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for the
LED descriptions.
Message 2 of 2
Discussion stats
  • 1 reply
  • 461 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
