Orbi WiFi 7 RBE973
Reply
Timeouts in RDP sessions
pmcglinchey
Follower
Hi,
I recently switched from a Verzon FiOS G3100 to a Nighthawk R7000 so I could return the Verizon router and not pay the monthly cost. Right after the switch I started getting connection problems on my RDP sessions I use for work. The Internet connection stays up and is fine. The connection restores in about 1 minute (on it's first retry attempt). It happens often and is very annoying. I'd love to fix it and not have to go back to the Verizon router. I've upgraded the firmware to v1.0.11.116_10.2.100 and still experiencing the same issue.
Thanks for any help in advance,
Paul
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Timeouts in RDP sessions
The verizon modem has a built-in router which may be causing issues with the R7000. You will need to set it to modem only or set the R7000 to AP mode.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 354 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
