- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Trouble with Denon AVR-X4300H Accessing Nighthawk X4S AC2600 R7800 Home WiFi Network
- Mark as New
- Bookmark
- Subscribe
- Permalink
Purchased a Denon AVR-X4300H and I'm trying access my home wifi network. I'm using Netgear Nighthawk X4S AC2600 Model R7800. Is there anyone on this forum familiar with the unit? Thank you for help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I went into Setup\Network\WiFi Setup and the AVR scanned for wifi networks. When it displayed mine I entered the password for the 5GHz band. That was it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Trouble with Denon AVR-X4300H Accessing Nighthawk X4S AC2600 R7800 Home WiFi Network
From the instructions it sounds simple on the Denon unit scan for wifi signals and select your's and enter your password for the network.
Here is a link to denon's manual https://usa.denon.com/us/product/hometheater/receivers/avrx4300h
I hope this by the look at page 237 in the manual good luck .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the AVR have a wired LAN port as well? I recommend using LAN port for best performances if your goingto use an AVR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
From I saw yes it has a 100mb wired lan port depending where the amp is located and the router located yours may be the best answer since in the end it all comes down to a static ip address on the network for the amp's network interface.
In fact it is on page 86,87 even tells how to connect and set up in the owners manual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess 100Mb is good enough. I presume no streaming with the AVR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks William10a. I figured it out last night shortly after I began this thread. I was a bit over tired and not thinking clearly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The network only would handling audio data no video data as the amp has 8 hdmi inputs with 3 hdmi outputs for the video part.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Awesome. Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
