Orbi WiFi 7 RBE973
Reply
USB drive does not show up readyshare
saucerman
I have a seagate 5T ssd that I try to plug into my x6 r8000.....sometimes it is recognized but all of a sudden the connect fails and then it will not connect at all
runnubng firmware V1.0.3.48_1.1.33  and I've even tried past versions to no avail.  it works sometimes but more often than not....the ssd works on every single compute without hesitation.
Suggestions?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
Re: USB drive does not show up readyshare
You have an SSD in a USB enclosure?
ReadySHARE is picky about the USB devices it accepts.
This list will give you some clues, although it is far from comprehensive:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
Not sure that any SSD works. How is yours formatted? Any partitions?
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 2 of 5
saucerman
it's an extenal 5 tb ssd drive that is connected via usb to the router.  The partition is ntfs.  It worked fine for a while then all of a sudden I have trouble seeing it.  Works perfect if I connect it to any pc...
Message 3 of 5
What have you changed in the meantime?
@saucerman wrote:
iWorks perfect if I connect it to any pc...
Unfortately, that guarantees nothing. PCs can use drivers that accommodate devices that will not work in a router.
Message 4 of 5
saucerman
the only thing that changed was the firmware of the router...I tried to revert back to the original one and that' didn't work either...
I was running KODI on the harddrive for over a year...the only thing I added to the harddrive were movies or TV shows.   That version of KODI or unix hasn't changed.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1241 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
