- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to Login to Netgear Nighthawk App Using iPhone
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am currently unable to login to my Netgear Nighthaw app via my iPhone. Firmware up to date and had already uninstalled/installed Netgear app.v Router is working fine and am able to log-in using my desktop but keep getting the message "WiFi Not Detected" when using my phone app. Router not in AP mode and "Local Network" is enabled. When I try again, the "Logon timed out, please try again" appears.
This has been going on for 2 weeks now.
Any helpful suggestions will be very much appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was able to fix the issue by doing a factory reset of my Netgear Nighthawk R7960P router.
Here's what I did:
1. Uninstall my Nighthawk app
2. Factory reset of my router
3. Reinstall the Nighthawk app
Hope this helps. Thanks to everyone who responded.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to Login to Netgear Nighthawk App Using iPhone
Im getting the same thing, di you get it to work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Negative. It would work for about an hour after I reboot my router (R7960P) but would stop working again after that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am using iPhone too, have you updated the Nighthawk app today? They recently released a new version that metions bug fixed and some. Hope that can help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, yes Im on the current version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something seems to have broken the iPhone app. Lots of reports around here. Try the "apps" section.
It isn't clear if it is something that Apple did or if it is Netgear being slow to catch up with things.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Quick question. Are we all using the same router model? Mine is R9000 and using firmware v1.0.5.18 (not latest) and using iOS 14.4 with latest Nighthack app and I haven't got this issue at all.
I was on iOS 14.3 yesterday and older Nighthawk app when I saw this thread and didn't have any problems either. So I don't think is app related but a combination of router firmware, app and network where router is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That makes sense. The trouble is that it is hard to pin down the exact sequence. People see an update and automatically assume that this caused the problem.
Something more subtle may well be in play here. That's why it helps to provide as much detail as possible.
If it is a firmware issue, then rolling back to earlier versions should restore functionality.
Unfortunately, it is probably harder to go back to an earlier app version. Android and iOS don't seem to allow that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's what I did:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. Did you reapply the current firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the firmware updated automatically when I did the factory reset, which was the same firmware that I had.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, I used the app to install the router settings instead of doing it on the desktop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the same problem - unable to login to Netgear Nighthawk App using my iphone. But was unsure about doing a factory reset of my router for fear it would create more problems. By resetting to factory defaults does that create any issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would not do that, I dont think it would help. I be;eive it to be a firmware problem with the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] By resetting to factory defaults does that create any issues?
It typically forces you to reconfigure your router. Should be
harmless otherwise.
> I would not do that, I dont think it would help. I be;eive [...]
I don't know if it would or not. In such a situation, some folks
would run the experiment.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
