Orbi WiFi 7 RBE973
Reply
Unable to login via nighthawk
yeshwanth
Follower
Unable to authenticate or login via nighthawk app, unable to authenticate gateway of provider as nighthawk not logging in, getting serial number already registered error
Model: R6120|AC1200 Dual Band WiFi Router
Message 1 of 2
Guru
Re: Unable to login via nighthawk
You didn't give us much to go off.
you have the R6120?
What firmware is on it?
What modem/gateway is it connected to?
You're having issues logging into it?
Have you tried factory rsetting it and reinstalling it?
push and hold reset for 7-15 seconds while its powered on and then follow the install guide.
https://www.netgear.com/support/product/r6120
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 312 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
