Orbi WiFi 7 RBE973
Reply
Upgrading to an R7000 replacing WGR61v10 for home use web access, texting [not for gaming]
38ta
For basic connectivity, No gaming, is it recommended to remove old router, WGR61v10, and go directly to Spectrum modem? Or connect through old router and if this option is used will this impede speed of new R7000?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 4
Accepted Solutions
myersw
Master
Re: Upgrading to an R7000 replacing WGR61v10 for home use web access, texting [not for gaming]
If you leave the old router in place, then you would need to put the r7000 into access point mode (AP mode). I do not understand why you would want to have an old box between the r7000 and the modem. IHMO, no question connect r7000 directly to the modem.
When you do there is a process you need to follow.
Power down both the modem and r7000
Now power up just the modem and let it initialize, about 5 to 7 minutes.
Now power up the router and if connected to modem the r7000 should be connected to modem and Internet.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 4
All Replies
myersw
Master
--Bill
Tesla > Edison
Message 2 of 4
38ta
My question exactly, but netgear "expert" was advising, connect through old router???
Message 3 of 4
38ta
By the way, Bill,  thank you for the quick response
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 632 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
