Orbi WiFi 7 RBE973
Reply
Upnp glitched?
roos5
Guide
Upnp glitched?
Hello,
My Upnp has been acting very weird lately, I've been using my XR1000 with my Xbox Series X for a while with no problem at all. Recently i got my PS5 and while i was using it via Ethernet cable everything was fine with both consoles, as soon as i moved my PS5 to another room and set it up via Wifi i notice that 2 ports (UDP 3074 and 9308) were always being used by the ps5 even if the console was fully turned off, since that i haven't been able to use port 3074 with my Xbox which is my main console for online gaming as of right now,  not even with port forwarding. I really want to fix this since i've been noticing some latency with my xbox, these are the things that i have tried already:
- Restart the router
-Turn off the router
- Unplug the router for 5-8 minutes.
- Fully shutdown the ps5
-Unplug the power cord form the ps5
I'll appriciate your assistance with this.
NOTE: Upnp  Portmap table shows both ports active and still being used by the ps5.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Guru
Re: Upnp glitched?
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-rout...
Thank you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 600 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
