Orbi WiFi 7 RBE973
Reply
VPN issues using ExpressVPN
Meccax
Follower
My client bought an XR500 router with the idea that since a client connects to the network via WIFI automatically enters the VPN without the need to add this new device, it has been difficult for us to do this and the only solution we have is to do it manual thing that is difficult for us and I would like to know what we are failing for this to happen
We have followed this guide to the letter and still nothing https://kb.netgear.com/000060463/How-do-I-set-up-a-Hybrid-VPN-on-my-Nighthawk-Pro-Gaming- router
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 2
Kitsap
Master
Re: VPN issues using ExpressVPN
You might get a better response if you posted in the community dedicated to Nighthawk Pro Gaming routers.
See here:  https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-rout...
A moderator will most likely move your post.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1733 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
