- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Vlan doesnt work correct
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried to make a vlan on port 1 and wifi for iptv, but when i do that my internet doesnt work. I have updated to newest firmware.
How can i solve this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Lech07 wrote:
I want to make a vlan for tv/streaming and one for internet. I need internet for both.
The feature is intended to configure the ISP-Internet-VLAN for router/Internet usage _plus_ bridge a dedicatged ISP-side VLAN used for IPTV to a dedicated LAN (or why ever also for the all the WiFi intefaces) to connect an ISP provided IPTV box using a dedicated cable or dedicated physical network connected on the selected LAN port(s).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Vlan doesnt work correct
You may want to take a look at this KB.
https://kb.netgear.com/000048453/What-do-I-need-to-know-about-setting-up-VLANs
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
The devices on the local network (LAN port(s) and/or WiFi) you bridge to the IPTV VLAN [assuming all configued correct] are lost for the normal Internet access as that would be a diferent VLAN. Note: On the LAN port(s) selected and the WiFi there won't be any VLANing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is vlan recommended to get better streaming?
I am running with a router from ISP in bridge mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
