Orbi WiFi 7 RBE973
Reply
WLAN config changes not possible
Ikarus92
Hi Guys,
I got a problem with my R8000.
At the moment its broadcasting the default configured SSID, but for security purpose I want to configure my own SSID / PSK.
But this doesn't seems to be possible.
When I try to save a change on the SSID / PSK Menu, it gets cancelled: This DFS-Channel cant be used because a radar gets detected. (Error message in german, I translated it, so therefore it could be, that it isnt the exact error message on a english ui)
BUT: The error appears even if the second 5G-Radio isn't even turned on, so therefore this shouldnt bother.
Further, the first 5G-Radio is sending on a non-DFS-Channel, so this couldnt be the problem either.
For me this seems to be a bug.
I'm using V1.0.3.4_1.1.2 which seems to be the latest version.
kind regards,
Andreas
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 13
Accepted Solutions
Ikarus92
Re: WLAN config changes not possible
Hi,
sorry, I forgot to write an answer in this topic since James forwarded the Support Contact informations to me in private.
The problem has been solved by installing the firmware "V1.0.2.44_1.0.96" on my R8000.
I'm not sure about the latest version for your EX6150, but for my R8000 the (in my opinion) stable version was listed under the previous versions section.
In your case I would suggest to install several of the older versions, and try to change the configuration to see, if the error appears again.
kind regards,
Andreas
Message 13 of 13
All Replies
JamesGL
Master
Hi Ikarus92,
Can you post the exact error message to check what seem to be the problem.
JamesG:
Community Team
Message 2 of 13
Ikarus92
Hi James,
the error message "This DFS channel is not allowed to use because the Radar was detected before. You can change another channel or wait" appears after I did any configuration changes on the following menu:
In Advanced -> Setup -> Wireless Setup
But as I already reported, the second 5G-Radio isn't even active (has been deactivated under: Advanced -> Advanced Setup -> Wireless Settings) and on the first 5G-Radio there isn't a dfs-channel choosen. It's running on channel 44
kind regards
Error Message
Message 3 of 13
JamesGL
Master
Hi Ikarus92,
Did you configure the smart connect of the router?
JamesG:
Community Team
Message 4 of 13
Ikarus92
Hi James,
no, it isn't configured.
kind regards
Message 5 of 13
JamesGL
Master
Hi Ikarus92,
I think the R8000 is set to AP mode since most of the features are disabled. Do you have another router that is working as the DHCP of your network? .
JamesGL
Community Team
Message 6 of 13
Ikarus92
Hi James,
 yes, the providers router is acting as dhcp and default gw in my network, the R8000 should just be the wireless lan ap.
I've deactiveted the "ap mode" now it's running as router (deactivated dhcp) but the error still keeps the same.
I'm wondering if nobody else suspected this error, since it seems to be a major bug on the system if you try to "customize" the ssid and psk settings.
kind regards
Message 7 of 13
JamesGL
Master
Hi Ikarus92,
What specific channel you were trying to use? Some DFS channels are not applicable depending on the region. It could be a reason why you are unable to use that specific channel.
JamesGL
Community Team
Message 8 of 13
Ikarus92
Hi James,
2,4 GHz: Auto
1. 5 GHz: 44
2. 5 GHz: 128 DFS
But as I already reported, I've turned of the second 5G at Advanced > Advanced Setup > Wireless Settings > Wireless Advanced Settings (5GHz-2 a/n/ac) > Deactivated checkbox at "Enable Wireless Router Radio 2" so therefore it shouldn't even matter what's configured on the site Advanced > Setup > Wireless Setup.
Just to exclude it: I tested configuring any of the second 5G channels, but none of them let me commit the configuration changes.
kind regards
Message 9 of 13
JamesGL
Master
Hi Ikarus92,
Please check your inbox.
JamesGL
Community Team
Message 10 of 13
Kdude
Tutor
I have the exact same problem & get the exact error about 'DFS channel not allowed & radar was detected before'. It appears to be a bug.
I'm using the EX6150 AC1200 wifi extender & it's been installed & configured for a few months & was working without issues. Now about once a week, for no reason, the EX6150 drops the 5Ghz connection to my router (which is handling DHCP). When I try to reconnect the 5Ghz either manually or using the wizard, the EX6150 will not let me save my extisting wifi network info, and returns the error about DFS channel & radar being detected before. So I'm stuck. However, if I cycle power to the EX6150, it sometimes starts working normally again, yet other times it does not.
THIS APPEARS TO BE A NETGEAR BUG!
This post was perfectly relevant to my issue, but NetGear did not post a solution. Only told OP to check their inbox.
What is the problem? And what is the solution ?
Message 11 of 13
JamesGL
Master
Hi Kdude,
I would suggest posting this issue in Extender board since this is for R8000 router.
https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/bd-p/home-wifi-range-extenders
JamesGL
Community Team
Message 12 of 13
Ikarus92
Hi,
kind regards,
Andreas
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 7441 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
