Orbi WiFi 7 RBE973
Reply
WLAN schedule cannot be activated
wolframmitbach
I find this topic again and again in the forum but no solution for me.
I want to activate 'Turn off wireless signal by schedule' but the box cannot be checked.
I'm using the R7000 as a Router it's on the latest FW V1.0.5.48_1.1.79 using a Chrome browser w Windows 10. (Edge doesn't work either)
Please Help
PS: There's no way to send a simple question to netgear support - thanks netgear! :-(((((
Message 1 of 4
Accepted Solutions
wolframmitbach
Re: WLAN schedule cannot be activated
Thanks it works now!
I didn't use WLAN scheduling bevor
Message 3 of 4
All Replies
JamesGL
Master
Hi wolframmibach,
Please reset the router to factory default and check if the you can enable it. By the way, was it working before prior to upgrading the firmware?
Message 2 of 4
wolframmitbach
Message 3 of 4
JamesGL
Master
Glad to know it works now.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2837 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
