Orbi WiFi 7 RBE973
Reply
WNR2000v3 firmware upgrade
Tomelk
I clicked on the "update available" button and it downloaded.  It then sent me to the Advanced Home screen and now it shows that the Firmware version is v1.1.2.18.  At the bottom of the box it has a tab that says REBOOT.....should i click this tab? or am i done?
Model: JWNR2000|Wireless-N Router
Message 1 of 3
Accepted Solutions
Guru
Re: WNR2000v3 firmware upgrade
When you say "it then sent me to the Advanced Home screen" did it install/reboot itself? Is should do this when its using the auto update. With that being said, 1.1.2.18 is the most up to date firmware. If its running fine, I wouldn't worrry about it. If you have any issues, I always recommend resetting a device after a firmware update. Saying that, if its working fine, I'd leave it.
Message 2 of 3
All Replies
Guru
Message 2 of 3
Tomelk
 Thank you for the response...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1183 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
