Orbi WiFi 7 RBE973
Reply
WPS button on Nighthawk ac2300 location?
chas638
Help
I'm trying to connect my Fire stick to my network. It asked me to press the WPS button on my Nighthawk ac2300 router but I can't find the button. I've looked all over the router but can't find the button.
Please let me know where it is?
Thank you
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 6
Accepted Solutions
chas638
Re: WPS button on Nighthawk ac2300 location?
Thank you
I would have never found it.
Message 5 of 6
All Replies
billmy1228
Guide
Go to
https://www.netgear.com/support/default.aspx
and put in your router model. That will take you to a page where you can download the user manual. Then you can read everything you wanted to know but were afraid to ask. Lots of good info.
Message 2 of 6
chas638
Hello
I downloaded the manual but it doesn't show where the button is
Message 3 of 6
antinode
Guru
   Which "the manual" did you download?  In the R7000P User Manual, look
for "Table 1. LED descriptions".  In particular, "WPS button with LED"
(on page 12).
   A careful observer might notice that the rightmost two LEDs are not
like the others.
Message 4 of 6
chas638
Thank you
Message 5 of 6
Message 6 of 6
Discussion stats
  • 5 replies
  • 21320 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
