Orbi WiFi 7 RBE973
Reply
Well, in 2023, almost all websites use HTTPS. So, is there a workaround here?
simwyck
Follower
I have the same issue and I tried adding the full URL (eg. https://www.domain.com) but it still doesn't block the website.
Thank you.
Message 1 of 4
microchip8
Master
Re: Well, in 2023, almost all websites use HTTPS. So, is there a workaround here?
Use NextDNS
Message 2 of 4
Same issue as what?
You are not the first, and won't be the last, to ask about https blocking:
Solved: Re: Block web sites not working on HTTPS Sites -->... - NETGEAR Communities
More background on @microchip8's suggested solution here:
Search - NETGEAR Communities – NextDNS
Or send more money to Netgear for its various subscription services.
Message 3 of 4
Guru
There is OpenDNS services as well.
Message 4 of 4
Discussion stats
  • 3 replies
  • 659 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
