Orbi WiFi 7 RBE973
Reply
What Ethernet Cables can I use for Nighthawk X6 AC2200?
CFerg11
Follower
My Nighthawk X6 Wifi Extender came with cat5 ethernet cable. Am I able to upgrade/replace it with either cat6 or cat7 cable and should I notice any difference in perfomance? With my current internet provider I have up to 1GB speeds.
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 2
microchip8
Master
Re: What Ethernet Cables can I use for Nighthawk X6 AC2200?
CAT5E is sufficient for 1 Gbps speeds. Anything higher and you need CAT6 (or 7 if you go much higher). You will not notice difference between CAT5 and 6 if your speed is around 1 Gbps
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 544 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
