- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What is the best R7000 firmware that support dd-wrt?
- Mark as New
- Bookmark
- Subscribe
- Permalink
so i bought this router and have heard it supports the likes of dd-wrt, what is the best firmware for this router and how do i go about installing it?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
As far as NETGEAR is concerned, we do not recommend the use of 3rd party firmware since it will void its warranty.
We always recommend that you update to the latest firmware version.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What is the best R7000 firmware that support dd-wrt??
That's a loaded question, since you have to ask I would suggest you use NG FW. While many swear by 3rd party it's a risk that may come back to bite you in the _$$.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since 1.0.7.2 is now available with just the briefest release note (fixes NTP issue), what is new/fixed/changed? Does it support Arlo (needed for my installation)? What else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seeing how I have nothing better to do today I'll try it. BBL
- Mark as New
- Bookmark
- Subscribe
- Permalink
No Arlo at first glance. I'll be back after I reload my settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any luck? Or is the silence telling? 😛
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reverted to previous FW 1.0.5.70 for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Greetings ArronLeeds,
While we cannot recommend you using a third party firmware for your R7000 Nighthawk Router.. If you do, only use DD-WRT Kong Mod found here Netgear R7000 Firmware remember to download the .chk file specific to R7000 model, and make sure to follow this manual for success on the update Firmware Installation Instructions
Thanks for fielding your question, and we hope you have a wonderful day!
