Reply
What is the intermitent red light on my Nighthawk X6?
TenaciousJ
Follower
Hi. Under the USB 2 series of down pointing triangle flashing lights, most of the the time the bottom light (#4) flashes white. Occassionally it turns solid red. I'm looking for any information regarding what this red light mean.
I can't find any info anywhere else.
Any ideas?
Thanks, Jeff
Message 1 of 2
Guru
Re: What is the intermitent red light on my Nighthawk X6?
what actual device is it? There's several that are x6
The label will have the model number on it.
With that, you can go to netgear.com/support/
type in the model number and it'll take you to the support site that has manuals that explains what each led is and what its color/blinking/solid means.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 182 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
