Orbi WiFi 7 RBE973
Reply
Which Nighthawk Routers will best support MESH networking with a MESH-enabled extender e.g. EX7500
davisrandm
Follower
Or, to put it another way, what router specifications will best tell me about its MESH capabilities.
Thanks for your help
Message 1 of 2
Accepted Solutions
Guru
Re: Which Nighthawk Routers will best support MESH networking with a MESH-enabled extender e.g. EX75
A mesh router? Orbi
Otherwise there isn't really a mesh router.
A mesh extender just simply uses the same ssid as the router and allows a devices (pc/laptop/cell/etc) to roam based on a roaming protocol. A full mesh system uses a controller that runs the satellites. Mesh extenders don't have that option.
If you're simply wanting a router to match with your extender, look at the performance of the extender and get "at least" the same performance from your router.
Message 2 of 2
All Replies
Guru
A mesh router? Orbi
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1106 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
