Orbi WiFi 7 RBE973
Reply
WiFi networks not showing up
TSTW22
Follower
When i click on the network tab it shows just my wifi networks and no outside wifi networks.  How can I get other networks to show in the list of available networks?
Message 1 of 2
Guru
Re: WiFi networks not showing up
On what ?
what router do you have?
What device are you using to check wifi networks?
Are you in range of other networks?
If you're scanning in windows, did you check with windows on why you're not seeing other networks?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 423 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
