dmizzone's avatar
dmizzone
Follower
Mar 21, 2023
Wifi not working
I reset router and still not working.
  • FURRYe38's avatar
    Is the wifi LEDs ON after you have reset the router and walked thru the setup wizard with a wired PC and web browser?
    What model R series router do you have? R6900?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    • plemans's avatar
      Did you push and hold the wifi on/off button for at least 2 seconds while powered on?
