Orbi WiFi 7 RBE973
Reply
Wink2
Retired_Member
Not applicable
Wink2
Greetings, My CAX80 using Comcast works fine when in wifi mode to Wink2 home hub, but it will not work using an ethernet cable from CAX80 to Wink2 home hub. I have tried different ports and different cables but I always come up empty. Has anyone had similar problem and are there fixes? Thanks, Lou F.
Message 1 of 9
Guru
Re: Wink2
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
I would contact the Mfr of the Wink hub device and ask for help and information regarding there product.
Thank you.
Message 2 of 9
Guru
Re: Wink2
Knowing nothing about wink hubs, 1 thing you can try is setting up the wink hub in the netgears DMZ when its hardwired in.
I'd also contact wink hub about this.
the netgear shouldn't be treating the hub any different when hardwired in versus wireless.
so it might be a question to ask wink about.
Message 3 of 9
Guru
Retired_Member
Not applicable
Re: Wink2
Furrye38,
Thanks for the info, I'll repost on the cable modem forum. Lou F.
Message 5 of 9
Retired_Member
Not applicable
Re: Wink2
plemans,
Thanks for the info. Lou F.
Message 6 of 9
Retired_Member
Not applicable
Re: Wink2
plemans,
I contacted Wink several times without a solution to my problem, they are not the easiest tech support to work with (email only and not very quick with answers). When you say setup Wink in DMZ, what do you mean? I'm unfamiliar with that type of setup. Could you elaborate for a newbie?
Thanks, Lou F.
Message 7 of 9
Guru
Re: Wink2
Message 8 of 9
Retired_Member
Not applicable
Re: Wink2
plemans, Thanks.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1196 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
