Orbi WiFi 7 RBE973
Reply
Wndr3700 reconnected 1yr later. iMac thru cat5 works but no wireless signal on laptop or phone. ?
Topdon
The computers and passwords are the same as before but no wireless signal.
Model: WNDR3700|N600 Wireless Dual Band Gigabit Router
Message 1 of 6
Guru
Re: Wndr3700 reconnected 1yr later. iMac thru cat5 works but no wireless signal on laptop or phone.
did the wifi on/off button get hit?
Push and hold it for 2 seconds while its powered on
Message 2 of 6
Topdon
I did push the lowest button called Push-N-Connect. I assum this is the wireless button. Thanks
Message 3 of 6
Topdon
push-n-connect did not work for wifi.
Message 4 of 6
antinode
Guru
   Is that accurate?  Look for "Model" on the product label.
> [...] I assum this is the wireless button. [...]
   Why assume anything?
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the Setup and/or User Manual (at
least).  Read.  Look for the LED descriptions and "Troubleshoot".
Further reading might not hurt, either.
Message 5 of 6
Guru
And you'd assume wrong. Like @antinode says, the manual is beneficial.
you can get it here:
https://www.netgear.com/support/product/WNDR3700v1.aspx
make sure to select the correct version from the drop drown box as there's 5 versions of the wndr3700.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 363 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
