Iceman64's avatar
Mar 27, 2019
X10 in Bridge Mode
Can someone tell me what do I give up or gain by setting my Netgear router to 'Bridge Mode.' I have (Verizon) Fios and their Modem/Router (Quantum) for my internet, tv and phone service. Right now they are both set as routers, however the ip addresses I get for my connected devices are completely different from the normal 192.1.168.1 values. They are all 10.0.0.1 -* in range. I'm no longer comfortable with this arrangement. I really hate to set a $500 router in Bridge mode, but I'm not sure if I'm getting the best use of my home system in this configuration.
BTW, I am not using any device on Verizon's 2.5 and 5 ghz SSID connections.
    • Iceman64's avatar
      Iceman64
      Guide
      Thank you for that info. I guess I will make the change in the morning. I find that nothing goes perfectly smooth when I do things like this. So tomorrow I will be fresh and ready for any surprises.
      • antinode's avatar
        antinode
        Guru
        > router to 'Bridge Mode.' [...]
           Why "Bridge Mode"?  What, exactly, does "Bridge Mode" mean to you?
           As usual, it might help if you explained the actual problem which you
        are trying to solve, rather than asking how to implement some particular
        "solution" (like, say, "setting my Netgear router to 'Bridge Mode'")
        which may or may not make much sense.
        > connections.
           Why not?
        > [...] Right now they are both set as routers, however the ip addresses
        > comfortable with this arrangement. [...]
           Presumably, you meant "192.168.1.*", but, in any case, ...
           Yes, cascading multiple routers can do that.  The usual solution is
        to configure one of the routers as something other than a full-function
        router.  One way would to do that be to configure the (unspecified)
        "(Verizon) Fios [...] Modem/Router (Quantum)" as a modem-only, leaving
        the R9000 as your (only) router.  With approximately no information on
        your mystery modem+router, I can't say whether that can be done.  Even
        if you could do that, I don't know if that change would disable its TV
        and/or voice capabilities.
           A second way would be to leave the mystery modem+router as your
        (only) router, and configure the R9000 as a wireless access point.
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual.  Read.  Look for "Use the
        Router as a WiFi Access Point".
           That would disable some router features on the R9000, but you may not
        care.  For details, see:
              https://kb.netgear.com/26765
           Knowing so little about your (unspecified) "(Verizon) Fios [...]
        Modem/Router (Quantum)", I'd recommend the R9000-as-WAP scheme, which
        should have little risk of disrupting your TV or voice service.  This
        scheme should put all your client devices on the same subnet
        ("192.168.1.*"), and allow them all to communicate with each other
        easily.
           Note that neither of these options involves putting the R9000 into
        "bridge mode".  Configuring your mystery modem+router as a modem-only is
        sometimes referred to putting _it_ into bridge mode.
           The R9000 has a bridge mode, but it's unrelated to what you're trying
        to do.  For comparison, look for "Set Up the Router in Bridge Mode" in
        its User Manual.  For a picture of that kind of arrangement, you could
        fetch the User Manual for a different model, the R7000, and look for
        "Set Up the Router in Bridge Mode" in _that_ User Manual.
        > Putting your X10 in bridge mode removes this problem.
           Not really.
        > [...] I guess I will make the change in the morning. [...]
           Making the right change might cause less pain (and fewer surprises).
