Orbi WiFi 7 RBE973
Reply
X4S R7800 Higher Ping
RobbieBeats
Hi,
I recently purchased the X4S R7800 Router. I went through all of the set up this morning. I put my ISP gateway into passthrough mode and disabled the wifi. I've connected my PS5 to the Nighthawk via Ethernet, but when I load up a game of FIFA, I'm getting 60-70% higher ping than previously when I was connected to the gateway via ethernet cable. I'm seeing 46-48ms ping compared to 26-28ms previously. It's not an enormous change obviously, but I did want to reduce that as much as possible, as I don't think there should have been any difference.
Let me know if there's anything different I should try and thanks in advance for the help.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
Re: X4S R7800 Higher Ping
It might help if you told people what that gateway is.
Passthrough mode is one of those terms that can mean various things. A genuine "bridge mode" that disables the router bit of a gateway would also disable wifi – no need to tirn it off – because that needs a router to work Just turning it off does not mean that the router bit is disabled.
Message 2 of 4
RobbieBeats
It's an Arris BGW210. I followed instructions online I found to set it to passthrough mode and turn the Wi-Fi off on the gateway.
Message 3 of 4
Thanks for the added details. That could be invaluable information for someone who understands this stuff
Do the instructions you used tie in with this?
(1) How To: Properly Configure The Arris BGW-210 For "Bridge Mode" (Walkthrough) : Ubiquiti
Bridge mode is the term I am more familiar with when playing with modem/routers like the BGW210. But bridge mode also means different things in different contexts. (Don't you love it in when techies use strange terms in different ways?)
Here is a more local reference:
Solved: How do I setup bridge mode in the ARRIS BGW210-700 - NETGEAR Communities
Found with this:
Search - NETGEAR Communities – BGW210
I have also seen reports here of AT&T devices being a pig to put into bridge mode.
Message 4 of 4
Discussion stats
  • 3 replies
  • 796 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
