Orbi WiFi 7 RBE973
Reply
can't logon to router locally without reboot and using cable
MikeFT
Follower
I have R7300 AC1900DST routers in 2 homes. Work pretty well and about 2 years old.  The problem with both is that I cannot easily access the router to make firmware upgrades and to set port forwarding etc.  I have tried the apps on my android phone and on the PC but the only way I can get into the router is after a router reset and running a long ethernet cable.  Surely this should be the simplest of tasks and as it is happening in both locations, this sounds like an issue that is not caused by me. Any help would be appreciated as both are out of warranty.  If I can't solve this I will have to buy two new routers from ma different brand as it is not something I can live with.  Thanks
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Re: can't logon to router locally without reboot and using cable
Same basic questions as here with your other conversation:
2.4 does not work 5GHz does - NETGEAR Communities
They are also relevant to this issue. My guess is the modem in front of the routers.
If you cannot login to your router | Answer | NETGEAR Support
Do you really own an A7000?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 435 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
