Orbi WiFi 7 RBE973
Reply
can we use ldap authentication for vpn in netgear nighthawk x10?
lotfib
Follower
Hello,
We have a Nighthawk x10 router with the following specifications:
DD-WRT v3.0-r43334 std (06/04/20)
and has this firmware:
and kernel version:
Linux 4.9.226 #460 SMP Thu Jun 4 00:59:50 +03 2020 armv7l
And we have PPTP configured for vpn connections of remote users and they are using the same username/password.
We would like to know, if it's possible to use our directory service, to make all users use their credentials (username/password)?
We would like to know, too if we can limit or control traffic of those users, what they can do when connected to corporate network via VPN? example, only RDP protocol is permitted?
Thank you in advance,
Model: Dual Band
Message 1 of 2
antinode
Guru
Re: can we use ldap authentication for vpn in netgear nighthawk x10?
   If you're using DD-WRT, then you're more likely to get useful advice
from DD-WRT people than here.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 263 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
