Reply
change device GHZ location
fuechy
Follower
I have nighthawk X6 Model R8000 router. How can I change some of my devices like iPad, iPhone from 5 GHZ to 2.4 GHZ  and TV from 2.4 GHZ to 5 GHZ? I need help on each device to select each device which best wifi network band for its location.
fuechy@gmail.com  Thank you!
Message 1 of 2
microchip8
Master
Re: change device GHZ location
Go to the router settings
Turn off Smart Connect if it's turned on
Name each band differently (eg, MyWiFi-2G, MyWiFi-5G, etc)
Routing: NETGEAR RAX43 - Firmware: v1.0.12.120 (1 Gbps down, 40 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2)
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 266 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
