tghien's avatar
tghien
Follower
Jan 30, 2021
got a message WIFI WEAK SECURITY WPA/WPA2 IS OT CONSIDERED SECU MY IPHONE S/W IS 14.4
How to fix that?
  • > got a message WIFI WEAK SECURITY WPA/WPA2 IS OT CONSIDERED SECU MY
    > IPHONE S/W IS 14.4
       Swell.  Now, what's your router (or wireless access point, or
    extender, or repeater, or whatever you have)?
       Look for "Model" on the product label.  Visit
    http://netgear.com/support , put in your (actual) model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for a
    topic like "Specify Basic WiFi Settings".  Select a security option like
    "WPA2-PSK [AES]", rather than any with plain "WPA" in it?
       Further reading might not hurt, either.
    • Polopony's avatar
      Polopony
      Initiate
      Had same issue, found that the extender was broadcasting WPA/WPA2. The phone was reading weak security. I fixed the problem by changing the extended to "WPA2-PSK [AES]" only. To do this I had to download the app called netgear nighthawk from iPhone sapp store. I then was able to get into the repeater and change the security protocol as noted above. Hope this helps...
