Orbi WiFi 7 RBE973
Reply
help
Sally20_GO
help
my router is not working
Message 1 of 2
Guru
Re: help
what router do you have?
what firmware is on it?
What modem/gateway is it connected to?
What are the led's on it doing?
Whats actually going on in details? "not working" doesn't tell us much.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 480 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
