mbista0624's avatar
mbista0624
Follower
Dec 09, 2022
how to reset security questions >
  • FURRYe38's avatar
    You gave us nothing to go off.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
    • microchip8's avatar
      microchip8
      Master
      Security questions can only be reset by doing a full factory reset. This also means you'll have to configure your router from scratch.
