Orbi WiFi 7 RBE973
Reply
nighthawk 7000
slaw720
Follower
nighthawk 7000
in the last couple days google chromecast has shown up on my list of attached devices. have currently disable network activity.  have added nothing that would be using chromecast.  have turned off and reset everything to no avail.  is there any way to delete chromecast from the attached device list/
thank you
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Guru
Re: nighthawk 7000
You have the R7000?
Have you compared what IP address the chromecast is whosing on to your devices?
I've found that the attached devices list doesn't always detect the proper device names.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 332 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
