Orbi WiFi 7 RBE973
Reply
nighthawk R7000 compatibility with Uverse modem
blemku
Follower
I am running my Uverse modem/router to my A7000.  I have a wifi signal but cannot connect to the internet.  The wifi on the Uverse modem is suppressed (bridge mode).  Do I need to change configuration? Can someone guide me as to exactly what configuation change is required and how I can do this without a network connection.  I am guessing I will need to get an ethernet adapter for my laptop so I can direct connect to my netgear router? Thanks.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Guru
Re: nighthawk R7000 compatibility with Uverse modem
Disabling the wifi doesn't disable the Uverse's routing functions. If its not in a passthrough/modem only mode, it causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 579 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
