Orbi WiFi 7 RBE973
Reply
parent control doesn't work any more
route123
Hello,
parent control in my router worked  all the time till a couple of days ago.
nothing is chagned for the device except I changed from netgear modem to xfinity cable modem recently. I am not sure if it is related or not.
I checked the DNS servers are correct:
208.67.222.123
208.67.220.123
the parent control in opendns login is set as Moderate.
Any suggestions to fix the problem?
Model: WNDR3700v4|N600 Wireless Dual Band Gigabit Router
Message 1 of 2
Guru
Re: parent control doesn't work any more
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 483 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
