Orbi WiFi 7 RBE973
Reply
r6700v3 - any way to remotely manage advanced settings?
tanzo
Follower
Remote management doesn't seem to be an option anymore without using the Nighthawk app. But I can't find a way to change advanced settings like port-forwarding in the app. Is there no way to manage these things remotely now?
Message 1 of 3
Re: r6700v3 - any way to remotely manage advanced settings?
Netgear has changed things over the years in response to security concerns.
Why is the Remote Management feature being removed from NETGEAR routers? | Answer | NETGEAR Support
Another way of "tunneling in", ReadyCLOUD, also died recently.
Support for ReadyCLOUD feature ends spring 2023 | Answer | NETGEAR Support
Maybe you could see if something like a VPN would let you carry on with this feature. Then again, your router, never one of Netgear's most powerful, is getting old. 2018 with its roots in a device from 2014.
Message 2 of 3
Guru
Have a running PC at the same location at the router and install a remote access app like Team Viewer or Remote Desktop and then access the routers web page thru the remote PC.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 418 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
