Orbi WiFi 7 RBE973
Reply
r9000 no wifi (ethernet works)
redmanh
Follower
I have an issue right now with my router. Just started this morning where the ethernet works. The ps4 is plugged in and we can stream and use the internet. The wifi isn't on and I can figure out what to do. I have already logged into routerlogin.com, couldn't find anything that was off and I unplugged and turned off both modem and router for more than 5 minutes.
Message 1 of 3
Accepted Solutions
Guru
Re: r9000 no wifi (ethernet works)
Did you push and hold the wifi on/off button for at least 2 seconds?
Message 3 of 3
All Replies
In the right order?
  • Turn off and unplug modem.
  • Turn off router and computers.
  • Plug in and turn on modem. Wait 2 minutes for it to connect.
  • Turn on the router and wait 2 minutes for it to connect.
  • Turn on computers and rest of network.
What firmware version do you have on the R9000 device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 636 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
