Orbi WiFi 7 RBE973
Reply
readyshare mount error(13): Permission denied
unkerjay
I'm using Linux Mint 18.1 Mate.  This WAS working.
Used: sudo mount -t cifs //###.###.###.###/USB_storage /media/public -o sec=ntlm
Prompted for password and I'm in.
That's NOT WORKING anymore.
Nothing I've tried seems to work.
I'm NOT using Windows, connecting to ANYTHING Windows.  This is STRICTLY a LINUX problem.
I CAN connect directly to the USB drive.
In, plain english (please), what can I do to troubleshoot this and fix it?
Thanx
Message 1 of 7
Accepted Solutions
unkerjay
Re: readyshare mount error(13): Permission denied
Ok, I've tried recommendations from the sidebar (excepting those for Windows as noted).  I've tried what I've found on the web.
And I've tried shumaku's recommendations.
NOTHING has made a difference.
So, I've connected it to a remote laptop and will access it from there when I remote connect to that laptop.
Either that or I may try USB over IP on a raspberry pi I've got set up in another room.
Readyshare works great, when it works.
Thanx
Message 5 of 7
All Replies
unkerjay
I checked my permissions.
I reset them using:
sudo chmod -R 777
I then went in and tried modifying files and I double checked that the permissions settings
matched the chmod.
Check on all counts.
I checked the permissions and chmod on the folder to which I was assigning the networked drive.
Check.
So, I'm running out of locations for checking the appropriate permissions.  Something I missed?
(Apparently.)  What?
Message 2 of 7
unkerjay
P.S.  I'm here to try to solve a problem.  Not to win a popularity contest. So, all the notifications to my ego
aren't working.  And this probably won't help.
Just saying.
Message 3 of 7
schumaku
Guru
Hm, not sure ... was this command line copied? Isn't the default share of the first USB drive /USB_Storage ?
Without authentication required:
# mount -t cifs //192.168.1.1/USB_Storage /mnt/readyshare/ -o guest
With a username and a password (another shared folder on the same Nighthawk):
# mount -t cifs //192.168.1.1/other /mnt/readyother -o user=admin,password=password,sec=ntlm
If uncertain, try --verbose or -vvv ...
# mount --verbose -t cifs //192.168.1.1/other /mnt/readyother -o user=admin,password=password,sec=ntlm
mount.cifs kernel mount options: ip=192.168.1.1,unc=\\192.168.1.1\other,sec=ntlm,user=admin,pass=********
You might want to provide the password on the command line - still specifying a username is suggested:
# mount --verbose -t cifs //192.168.1.1/other /mnt/readyother -o user=admin,sec=ntlm
Password for admin@//192.168.1.1/other:
If you are using the same username, you can do it without the username:
# mount --verbose -t cifs //192.168.1.1/other /mnt/readyother -o sec=ntlm
But wait, you are sudo ... and then you become root
# sudo whoami
root
Hope this gives some ideas. And then ... I've seen Linux distros breaking simple NFS mounts as well as mount.cifs.
-Kurt
Message 4 of 7
unkerjay
Thanx
Message 5 of 7
schumaku
Guru
The ReadSHARE is a plain simple (and outdated, vulnerable, ...) SAMBA 3.0.24 serving SMB 1.0 protocol, and max ntlm auth security on all Nighthawk routers.
Well, I'm still convinced it's either a problem between keyboard and chair, or a problem with your Linux distro, the SAMBA Kernel module in place, the SAMBA utilities in place, ..
Message 6 of 7
unkerjay
That and a dime, along with all the other recommendations not fixing the problem.
There's a number of places this problem (and its solution) could be hiding.
My goal was to be able to access the data remotely.
I've accomplished that.  Just no longer through ReadyShare.
USB over IP, as I've read has it's problems too.
But, remote access to the PC to which the drive is connected is working.
I can continue to attempt to resolve the problem through ReadyShare, through
Linux config.
Or, I can go with what works.
Sometimes life is too short.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 9855 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
