Reply
router won't login on Chromium based browser
ambimom
I have used a Chromium based browser for years (Vivaldi) and have never had any difficulty logging into the router, but all of a sudden in the latest iteration of Vivaldi, this is what happens.  I fill in all the data, and it just loops back to this screen.
Luckily I am able to log in using Safari.
Don't understand why this is happening.  Any suggestions?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
Accepted Solutions
ambimom
Re: router won't login on Chromium based browser
Found the solution, thanks to Dustin.  This is what I did and I'm back in.  THANK YOU
a. Paste chrome://flags/#http-auth-committed-interstitials into a Google Chrome Browser
b. Click the down arrow to change from Default or Enabled to Disabled
Message 2 of 3
All Replies
ambimom
Message 2 of 3
Thanks for that report.
We can add Chromium to the browsers that have caused hiccups after an update.
Be warned that some things won't work in Safari. Password recovery, for example.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1272 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
