Orbi WiFi 7 RBE973
Reply
wifi signal strength
boopajoo
Follower
Is there a way to see the signal strength of connected devices, I have been searching all over my netgear to find this.  I have a $50 hap ac lite mikrotik router that has this option, I feel like my $200+ netgear must have it somewhere as well.
What I'm looking for is something like this(attached picture, because the picture refused to load on the post), that tells me the connected devices tx and rx signals so I can find out if the computer is slow, or the router just isnt good enough to push signal upstairs.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 5
Guru
Re: wifi signal strength
Something that NG doesn't support on there router products. Would be nice though. I remember when other router mfrs had this.
Message 2 of 5
Try WiFi Analytics in the Netgear desktop genie for your operating system.
https://www.netgear.com/support/download/?model=genie
Message 3 of 5
Guru
Message 4 of 5
WiFi AnalyticsWiFi Analytics
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 960 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
