×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Add satellite MR60 to MS80
Hutcherml
Follower
Are there conflicts to mixing the MR60 (satellite) with the MS80 network?
Message 1 of 3
Guru
Re: Add satellite MR60 to MS80
Not too sure. The 60 series may work. Just won't have the 3rd triband backhaul that the 80 series has.
I only have the 60 series.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 3
Guru
You can use MS60 satellites with the MS80 satellites but you can't use the MR60.
The following configurations are supported with the MK83:
  • MR80 + MS80
  • MR80 + MS60
  • MR80 + MS80 + MS60
Which Nighthawk Mesh products are compatible with the Nighthawk Tri-band Mesh WiFi 6 products? | Ans...
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Discussion stats
  • 2 replies
  • 484 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
