× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Did a firmware update through the nighthawk app and now have no internet
adrnln8
Same problem - did a firmware update through the nighthawk app and now have no internet connection. I can see the network on my phone and laptop, the nighthawk app recognizes the router, no internet connection. I've tried rebooting, I've tried completely resetting the router. No connection. Reverting back to my Asus RT-AC1200 because it works and connects flawlessly, just slow. Please help!
Message 1 of 9
Accepted Solutions
adrnln8
Re: Did a firmware update through the nighthawk app and now have no internet
This has been a bear but I think I have it figured out.  Got a usb-c to ethernet dongle so I could use my laptop and upload the firmware the correct way as linked above.  At first, nothing changed and I was still having issues with no connection to the internet.  After a couple hours of factory resets and making sure the firmware uploaded correctly, I did some research in this community and found more information from someone who was having similar issues.  He set the IPv6 to Pass Through and it solved his problem.  While that didn't work for me, I set mine to Auto Detect and this did the trick.  It was on "Disabled" by default.  Not sure why the default for IPv6 is set to disabled but setting mine to Auto Detect has solved the problem for me.
Thank you for your help!
Message 6 of 9
All Replies
Guru
What FW was loaded on the MR and MS?
Did you update the MS first then the MR lastly?
Did you manually update the system as seen here?
https://community.netgear.com/t5/Nighthawk-Wi-Fi-6-AX-Mesh/New-MR60-MS60-Firmware-Version-1-1-7-134-...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Message 2 of 9
adrnln8
I did not manually update per that link - I did the update through the Nighthawk App on my phone. (anytime you go to routerlogin.net, there is a strong and borderline forceful recommendation to use their app)  Maybe this is the issue?
We do not have a computer/desktop connected to the network, only a couple laptops and none of them have ethernet ports making all of this rather difficult.
I've run through all those steps you list below, done all the reboots and factory resets in the correct order and it gets me back to the factory settings with the factory Network ID and Password.  From there the only thing I am doing custom on my end is changing the Network ID and Password.  As soon as I do that and the router reboots, I lose internet connection.  Anytime the router reboots after that initial hard reset, it loses internet connection.  Maybe when the MR60 reboots after I enter my preferred network info, I need to reboot the modem also in the correct sequence?
We have Xfinity/Comcast service and I'm using my own Netgear CM500 modem.  Maybe this needs to be updated or even upgraded?
I have a feeling that Xfinity might be behind this because they want me to use their modem/router to broaden their Xfinity Mobile network . . . secret sabotage of customer's private equipment.
Message 3 of 9
Guru
Seen problems of the NH app not correctly updating both MS and MR or doing the update incorrectly causing problems. Why it's recommended to update manually using a wired PC and web browser and loading the FW files.
It is expected that when you make changes on the MR, that there will be a temporarly loss of internet services as the MR has to make changes and or reboot which would cause this tempoary disconnect. After the MR is back to ready, there should be internet service access.
Shouldn't need to reboot the modem however might be good to try this now and see. MIght factory reset and setup from scratch as well.
Message 4 of 9
adrnln8
So it sounds like I need to be hard wired to do this firmware update. Let me work on that and I'll get back to you.
Message 5 of 9
adrnln8
Message 6 of 9
Guru
Does your ISP support native IPv6 by chance? Just wondering.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 7 of 9
adrnln8
Yes, my ISP Comcast/Xfinity does support IPv6.
Thanks again.
Message 8 of 9
Guru
Message 9 of 9
Discussion stats
  • 8 replies
  • 7135 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
