- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Help disabling Armor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can someone help me figure out how to disable Armor? It's been causing me numerous issues, especially with video conferencing software.
I go into the Nighhawk app -> Settings -> Security -> slide the enable netgear armor swith to OFF, but it always times out with an error saying the process took too long (60 seconds).
Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Help disabling Armor
Try uninstalling the app and reinstalling it?
Do you have a different device to try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes - I've tried installing the app on another device, same problem. Rebooted router, restarted app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you really want it disabled, factory reset the router and reinstall it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, but I've seen in other threads that doesn't work. The device is registered with the Armor service and it's immediately activated again after the factory reset?
@plemans wrote:If you really want it disabled, factory reset the router and reinstall it.
